Battery removal help
jonnyZZZ
Post by jonnyZZZ » Tue 12 Dec, 2017 22:54
Hi I want to remove the battery for the winter but when I disconnect a terminal the alarm goes off :( is there a way of stopping this please.
therealdb1
Re: Battery removal help
Post by therealdb1 » Wed 13 Dec, 2017 11:30
Is this a factory fit BMW alarm?
With the lid open to disconnect the battery the alarm will not be armed so it shouldn't be triggered.
If it is an aftermarket one you'll need to find where it gets its back up supply from and disconnect that.
Post by Robert T » Wed 13 Dec, 2017 18:33
Hi Jonny and welcome to the forum.
I see that you have a 1997 car, so if it has the original alarm, it will the type with the separate fobs and a little round key.
The alarm siren has a backup battery, which causes the siren to sound if the main battery is disconnected.
The little round key can be inserted into a key switch on the siren and turned to disable the siren.
jonnyZZZ
Post by jonnyZZZ » Thu 14 Dec, 2017 07:28
Thanks Robert for the input. In the last 20 years keys seem to have gone missing as I do not have a remote key or separate fob, the central locking works ok off the door/ignition key, I don't actually know if a remote system was fitted to all early cars, so I think I need to delve a little into the alarm system. Through lack of garage space it is having to spend the winter outside but covered over and just want to keep the battery in the garage and charged up, I do this with another car I have. Further investigation might have to wait until after Christmas.
Jonco
Post by Jonco » Sun 17 Dec, 2017 13:44
Agree with Robert - the back-up for the original alarm has limited capacity and will drain in a short period after disconnection if you can put up with the noise. If you look in the right side of the engine bay you will be able to see the siren if it's an original. I have a photo but unable to load it on here.
EDIT Have a look at viewtopic.php?f=5&t=45506 for picture of original EWS siren.
jonnyZZZ
Post by jonnyZZZ » Mon 18 Dec, 2017 15:34
Thanks guys for the input. I presume that when the battery is reconnected the siren will re charge, not that anyone would take any notice of it, its not exactly deafening :lol:
Jonco
Post by Jonco » Mon 18 Dec, 2017 22:16
Yes it recharges on re-connection - have done it several times on mine but admittedly only for a few days at a time - you could consider a ctek trickle charger if you can run a poor supply to the car.
