Next on the list - leaking boot.
dazthephot
Post by dazthephot » Sat 20 Jan, 2018 14:20
So I’ve been thinking all along that this is just condensation from there being water in the boot wells. Now I’m thinking it’s the prime cause. What do you think?
Re: Next on the list - leaking boot.
Post by BladeRunner919 » Sat 20 Jan, 2018 16:59
The condensation is almost certainly just a side effect of moisture in the boot. Have a good dig around under the carpet for water, particularly where there is a 'well' either side behind the wheelarch.
dazthephot
Post by dazthephot » Sat 20 Jan, 2018 18:38
Yeh I thought so too. Back to the drawing board. I’m gunna have to take out the whole carpet.
Boosh
Post by Boosh » Sat 20 Jan, 2018 19:33
I also had condensation I couldn't get rid of, and suspected a bad seal at the bottom of the hood. I therefore took the "parcel shelf" carpet off, to find... nothing. Absolutely dry, and no sign of previous leakage. Once I got rid of the condensation (leaving the boot open in the garage for a few days), it never came back. I reckon it was due to an overly important downpour while the car was parked nose slightly up, which prevented the water from making its way to the little drain behind the b-pillar, and overflowed into the boot.
Hope that helps, though it seems that you'll need to have a butcher's to be sure. Mind you, the third brakelight seal, on the bootlid is notorious for failing and letting water through...
Keep us posted,
Boosh.
dazthephot
Post by dazthephot » Sat 20 Jan, 2018 20:02
I haven’t seen that drain yet so I will check that for definite. Thanks.
I’ll be sure to report progress as I’m sure I’m not alone on this issue.
I nipped up the nuts on the third brake light but I saw little score marks which looked like someone had been fiddling before. Maybe a new seal wouldn’t go amiss anyway.
Post by mrscalex » Sun 21 Jan, 2018 09:39
I have exactly the same issue on a project car. But I’m not going to get to it for some weeks.
I know all the places it can leak from so I’ll check through and report back in due course.
The nastiest one is the roof. Not a difficult job but you need to do your research first and find 6-8 hours for it.
dazthephot
Post by dazthephot » Sun 21 Jan, 2018 13:02
Oh blimey, fingers crossed it’s not that eh!!
Be great to see how you get on.
Users browsing this forum: Google [Bot], stupot50 and 3 guests
