Replacing the rear shock top mounts (with OEM parts)
Postby JontyP » Sun 16 Sep, 2007 16:37
I know it's a simple job but I thought I would add a little "how-to" since I did mine today.
First job before you jack up the car is to get at the top of the shock behind the seats. Just peel back the lining to expose the top of the shock. You will only need to pop out one of the push-in fixings to do this.
Image.
Next remove the rubber cap (just so you don't have to struggle with it when the shock is free).
Undo the two fixing nuts and remove them. The shock won't go anywhere for now. Next you can jack up the rear of the car. This will allow the shock mount to come away from the inside of the wheel arch.
Now you need to undo the lower shock fixing bolt. A squirt of WD40 is helpful here although mine were easy enough.
With that bolt out the shock can be removed. Don't forget to remove the old gasket from the inside of the wheel arch and clean the area to allow a good seal when re-fitting. With the shock in a vice gripping the flats machined on the end of the push-rod you can now remove the mount fixing nut.
This then allows the removal of the old shock mount. Here are a couple of shots of the split drivers side mount.
You can now fit the new mount (in the reverse order of the removal process :roll: ) along with a new gasket.
Offer this up the the car and fit the bottom fixing bolt (torque this to 77Nm)
Refit the wheel, lower the car off the jack and tighten the two mount fixing nuts inside the cabin. Refit the rubber cap and replace the lining. Repeat for the other side and job done. Here is how the passenger side mount came out :shock:
JontyP
Postby Gazza » Sun 16 Sep, 2007 19:31
Very nice easy to follow write up.
How long did the replacement take you as a first timer?
Gazza.
Gazza.
2001 M roadster S54 Image 1965 Mustang 289 Fastback, 1968 Mustang Coupe 331 Stroker, 1967 Mustang 289 Fastback
Postby JontyP » Mon 17 Sep, 2007 07:22
Maybe 1/2 hour per side but I really wasn't rushing and I was taking the piccies aswell. Most of that time was walking from garage to drive and back :roll: .
Jonty
JontyP
Postby Rob13 » Tue 27 May, 2008 20:09
Hi - I had a knock when going over even a slight rumble and changing the top mounts sorted it out :-)
Just a tip - the top of the damper can be eld with a 6mm spanner to take the nut off - that way the wheels and dampers can stay in place - just jack the car up, slip off the mount and slip on the new one - 15 mins a side!!
Rob13
Postby SpunkyM » Wed 28 May, 2008 12:24
You don't really need to take the wheels off anyway - I just reversed mine up onto a couple of block of wood to get a bit more clearance for my belly under the back of the car!
SpunkyM
Postby coetzejg » Wed 22 Oct, 2008 12:52
Can anyone please give me the part number for this mount?
coetzejg
Postby Gazza » Wed 22 Oct, 2008 13:07
Mount 33521092362
washer gasket x2 33526751174
washer gasket x1 33526772864
http://www.realoem.com/bmw/showparts.do ... g=33&fg=45
Gazza.
Postby Guest » Wed 22 Oct, 2008 14:36
Guest
Return to Z3 range knowledgebase
