Rain water collecting in the fuel filler flap
I've noticed that rain water is collecting within the fuel filler, somehow getting into the flap and making a nice little pool under the filler cap. Is this common, or is there meant to be a seal around the inside of the flap? Mine obviously has a gap around it and was wondering the best way to address this.
Thanks a lot.
Andy
Thanks a lot.
Andy
No seal, but there is a drain hole in the bottom of the rubber boot which gets blocked. Just needs a gentle poke with something long and pointy and a good sluice through with some clean water. Think I used a wooden kebab skewer last time. We've probably all had this problem at some point or other.
How many times have you answered this question now Rob?Robert T wrote:No seal, but there is a drain hole in the bottom of the rubber boot which gets blocked. Just needs a gentle poke with something long and pointy and a good sluice through with some clean water. Think I used a wooden kebab skewer last time. We've probably all had this problem at some point or other.
Knowledgebase
Someone should place a detailed article with pictures in the Knowledgebase, but it's virtually impossible to do so these days.
I used to be the Knowledgebase Moderator, but somehow I got the sack a few months ago - don't know why . . .
I lost count, but the drain hole is still in the same place.Dave L2 wrote:How many times have you answered this question now Rob?
Mike, I suspect that it is more to do with the level of admin rights you would need to move posts into a restricted forum than anything to do with your moderating skills. A sticky with the submission process wouldn't go amiss (Mods - pretty please).
Re: Knowledgebase
Probably when your account went to Guest you lost your permissions.Mike Fishwick wrote:I used to be the Knowledgebase Moderator, but somehow I got the sack a few months ago - don't know why . . .
My tiny hole
Just had same problem, the hole is tiny and gets blocked so easy. I gave it a blast with the hose and watched as it drained onto the sill and also under the car.
