Hubcentric spacers for 2000 2.0 Z3
daveofedinburgh
Post by daveofedinburgh » Wed 02 Mar, 2016 20:38
Hi all,
As per the thread title really, what specs should I look for to fit my car and recommendations for where to buy would be great.
I'm sure many of you will be thinking 'don't fit spacers you tart' but I do want to improve the overall stance (in a subtle rather than 'scene' way) and won't be going mad, maybe 15mm spacers for example.
A SENSIBLE drop may also be on the cards so recommendations for springs/ dampers would also be appreciated.
Dave.
2000, 2.0 manual, topasblau, blue leather. Now for sale: viewtopic.php?f=11&t=40699
stevov
Re: Hubcentric spacers for 2000 2.0 Z3
Post by stevov » Wed 02 Mar, 2016 21:38
JJC rally. 15 mm hubcentric supplied with longer bolts. Do not get the spacers that bolt on to your hubs and then you bolt the wheel to the spacer. A search will show why.
beerbelly
Post by beerbelly » Wed 02 Mar, 2016 21:49
I think I have a pair of 10mm ones I don't need new only fitted to see which ones I preferred I ended up leaving 15mm ones on these were fitted to our 1999 2.8 I assume the hubs are the same size
daveofedinburgh
Post by daveofedinburgh » Wed 02 Mar, 2016 21:53
stevov wrote:JJC rally. 15 mm hubcentric supplied with longer bolts. Do not get the spacers that bolt on to your hubs and then you bolt the wheel to the spacer. A search will show why.
Great help there stevov, exactly what I'm after!
Can I just double check with those more mechanically literate than me, is it these ones (they seem cheap to me!);
Link:
http://www.jjcraceandrally.com/race/whe ... z8-e52-z4m
daveofedinburgh
Post by daveofedinburgh » Wed 02 Mar, 2016 21:58
beerbelly wrote:I think I have a pair of 10mm ones I don't need new only fitted to see which ones I preferred I ended up leaving 15mm ones on these were fitted to our 1999 2.8 I assume the hubs are the same size
If someone can confirm that these will fit my 2000 2.0 I could transfer afew beer tokens to cover your time/ postage costs beerbelly...
stevov
Post by stevov » Wed 02 Mar, 2016 22:21
That's the set I fitted to my car a year ago.. Well priced and good quality
Post by BladeRunner919 » Thu 03 Mar, 2016 08:22
That is a good price.
stevov
Post by stevov » Thu 03 Mar, 2016 08:48
Good website and good company to deal with. Well priced throughout their range.
