Tilt sensor
dazthephot
Tilt sensor
Post by dazthephot » Thu 06 Jul, 2017 21:28
Just a quick bump. One of the wires has broken off the tilt sensor wiring block
Can you buy replacements? Or get new female pin connectors to solder on?
Re: Tilt sensor
Post by colb » Thu 06 Jul, 2017 22:07
Doubt you will get a pin it will only come as a unit from BMW
One on ebay at the moment http://www.ebay.co.uk/itm/BMW-Z3-E36-Al ... SwstxVUKxX
or
Ask spurs fan on here if he has one from his stock of parts.
Re: Tilt sensor
Post by BladeRunner919 » Fri 07 Jul, 2017 08:33
Actually, all the connectors and pins are available from BMW - you just have to search out the part numbers on Realoem, in the 'Vehicle Electrical System' section, which can be 'challenging'!
Re: Tilt sensor
Post by colb » Fri 07 Jul, 2017 09:14
http://www.realoem.com/bmw/enUS/showpar ... Id=65_1011
Is it the pin in the cable connection plug that needs replacing as opposed to the socket pin in the tilt sensor?
Have a look here for repair kits for supplementary wiring bits
http://www.realoem.com/bmw/enUS/partgrp ... 3_19&mg=61
dazthephot
Re: Tilt sensor
Post by dazthephot » Fri 07 Jul, 2017 09:42
It's the wire that goes into the black block connector that's broken and corroded so i thought i could get a replacement female micro pin and dig out the corroded one in the block, then solder the new female pin on to the wire and insert it back into the block.
I suspect some of the other wires are corroded too so i may as well get another 5 or 6 and replace them all.
Or leave the tilt sensor disconnected as a bodge but then i don't like to do that.
Re: Tilt sensor
Post by colb » Fri 07 Jul, 2017 09:50
Ok so if you look through the second link I posted you should find what your looking for.
dazthephot
Re: Tilt sensor
Post by dazthephot » Fri 07 Jul, 2017 09:52
Thank you my friend, looking now.
dazthephot
Re: Tilt sensor
Post by dazthephot » Fri 07 Jul, 2017 10:12
I think it's this one. I'll have to call BMW and see what's included in the repair kit..
http://www.realoem.com/bmw/enUS/showpar ... Id=61_4933
Plug number 6
Brian4
Re: Tilt sensor
Post by Brian4 » Sat 15 Jul, 2017 19:35
Yes thats the one £9.76 when I bought it 03/2016
3.0I Topaz Blue
2000 E36/7 Z3 3.0i
2016 F31 335d
2015 F21 118i
dazthephot
Re: Tilt sensor
Post by dazthephot » Sat 15 Jul, 2017 20:18
Beauty, thank you
