long way arround screen washer pipe
Post by peter2b » Sat 09 Sep, 2017 09:26
the screen wash stopped working the other day so I had a look under the bonnet pump was making it nomal noise so I thought I would see if the pipe was blocked, from the washer tank (near side by the wind screen)the pipe goes across the back to the off side through a pannel by the fuse box down under the fuse box up again to the front of the fuse box through the pannel again arround the offside of the fuse box then up to the bonnet to the jets, I pulled off each junction to see if the pipe was blocked from the jets to the first junction by the fuse box -just a dribble ,new pump on order.any one no why the pipe goes all the way arround the car rather than just straight up from the tank to the bonnet -jets
peterz3
Howard Adams
Re: long way arround screen washer pipe
Post by Howard Adams » Sat 09 Sep, 2017 13:11
I had the same problem with my washers not working, if you remove both pumps (if headlamp washers fitted) then take the pump grommets out, these incorporate a filter which blocks up & is often overlooked.
Hope this helps.
AdyDurn
Post by AdyDurn » Sat 09 Sep, 2017 21:06
Have always wondered why the washer fluid does a lap of the engine bay before getting near the screen.
Post by mrscalex » Sat 09 Sep, 2017 23:24
Remember that on some Z3s the washer bottle is front left of the engine bay not rear right. It's possible BMW wanted to keep a single entrance point up onto the bonnet.
Buz007
Post by Buz007 » Tue 12 Sep, 2017 13:59
prevents freezing in cold temperatures. The engine warms the pipes
Post by peter2b » Wed 13 Sep, 2017 10:25
good tip Howard fitted a new pump but the mesh screen under the pump had a load of green gunk over it, sorted
peterz3
Users browsing this forum: Yahoo [Bot] and 5 guests
