soft top ram
soft top ram
Post by peter2b » Fri 27 Oct, 2017 19:21
the other day dropped the top as the sun was out but when I tried to get it to go up again the cup poped off the ball, the clip is still in the correct place( had a problem last year when the ball cought the edge of the hard top mount and pulled it apart , I fixed it ok) now even when I do a manual lift the fitting splits about 1/3 of the way up , is the cup end of the ram a replacement part or do I need another ram?
peterz3
NZ00Z3
Re: soft top ram
Post by NZ00Z3 » Fri 27 Oct, 2017 22:14
Hi Peter
The assumption I'm making is that you have a face-lift Z3 with a manual soft top. The gas ram that assists the raising of the soft top are getting to an age where they die. I have replaced one that seized and the top sleeve came off the rod completely, letting the ram rattle around. They are readily available from BMW. Alternative suppliers are hard to find (special size gas ram).
I suggest getting a new ram. They are relatively easy to replace.
Muzz
Re: soft top ram
Post by peter2b » Sat 28 Oct, 2017 09:03
cheers yes she's a facelift zed 2001 any idea how much the ram was?
peterz3
