Halfords Aftermarket Radio
Lancsbob
Post by Lancsbob » Wed 13 Dec, 2017 14:24
Am going to get Halfords to fit an aftermarket radio in my 2002 Z3 2.2 & their
site says it just needs a converter harness at back of radio but i have removed
the amp & multi changer from the boot to give extra space leaving unconnected wires,
will they need to do any extra work to get new radio up & running?
Cheers Bob
Re: Halfords Aftermarket Radio
Post by Robert T » Wed 13 Dec, 2017 18:37
The connector for the original BMW headunit is a BMW-specific connector. You will need a BMW-to-ISO adapter cable. The headunit should have a cable that takes it from ISO to whatever is on the back of the headunit.
If you have removed the amp, then how are the speakers connected at the moment? There may be some more wiring to do here.
Lancsbob
Post by Lancsbob » Wed 13 Dec, 2017 19:17
I have just removed the amp & cd changer & left it IE no radio working.
Iv'e just now after a couple of years decided to give myself a Christmas present
& have an after market radio/cd fitted & don't want to do it myself but am
sure its not just connect/fit & go.
Halfords has told me it needs a harness adaptor but am sure it wont be just that,
i'm sure it will need some work at the boot end. I think someone has said that it just
needs to be linked out at the boot wiring. I just want to be able to tell the Halfords
fitter what needs to be done. I just don't want to do it myself.
Oh, and the original head unit is still in place.
Thanks for reply.
Bob
Post by Gazza » Wed 13 Dec, 2017 21:37
Everything is wired to the BMW adaptor so when they fit the ISO adaptor to the BMW adaptor all should be fine.
I removed my cd changer and amp but didn't change any wiring.
siwilson
Post by siwilson » Thu 14 Dec, 2017 08:21
You will need an adapter, but it depends on what system you had as to which adapter is needed. Does the speaker grill in the middle behind the seats say Harmon Kardon on it? If so you had two amps and may need a different adapter. if there is no Harmon Kardon badge then you had the Hi-Fi system which just added a subwoofer, powered by the amp you removed.
Post by peter2b » Sat 16 Dec, 2017 17:59
I took out the cd player etc from the boot and fitted a dab radio /cd into the hole that was left when I got my z3 I think it was a kenwood unit but no front facia the dab arial sticks to the screen just above where the old tax disc was
peterz3
Lancsbob
Post by Lancsbob » Tue 19 Dec, 2017 07:29
So i went to Halfords & they wouldn't touch it,said it was too complicated
& required extra work to the wiring which they wont touch.
Am waiting for a quote from a profesional hifi fitter but
he's saying all the speakers will need re-wiring so i think his
quote will be very large.
Peter did you do anything to the wires in the boot as i'm
told the speakers wont work as they were connected through
the old amp in the boot.
Bob
Users browsing this forum: No registered users and 9 guests
