Drivers window
- chris1984_99_99
Drivers window
Hi all, I noticed today that my driver side window is playing up, it goes down ok.... and it will come up so long as i hold my finger on the button... but it used to come all the way up on its own, has anyone any ideas why it could be going like this? Ive had a look and couldnt find any previous threads on this!
You are aware that the window switch has a double click and fully up on the window requires pushing down to the second click on the switch. It is not unknown for the 'system' to lose where it is on the wondow control. I have this method of getting them in 'sync' again in my files. I repeat it here but I don't know if it works!
Resetting electric windows.
...Ignition on, press the "down" button and hold it down at the bottom of the movement for an additional couple of seconds, do the same for the "up" and hold for a couple of seconds again.
...To reset the side window cycle (one-touch up/down feature) you need to lower the window, then press and hold the up button and continue to hold it for 15-20 sec after it gets to the top. Same with the one touch down.
Hope this helps.
Hope this helps.
- chris1984_99_99
