Traction control + ABS lights permanently on
Can any offer me any advice on how i could diy fix my traction control and ABS light problem. I have a peake tool reader and they dont diagnose ASC/ABS. Had a look at taking abs sensors out. But once i removed the bolt i found they were stuck in solid. Anyway to check them with out removing them.
I don't think you can check them without removing them. One of mine was difficult to remove, and needed some force! In hindsight probably quite lucky I didn't snap the head off the bolt. Be careful!
Maybe worth trying to keep the bolt soaked in some WD40 type stuff for a day or so.
BMW Z3 2.0 Titan Silver - Progress Thread
(Pictures - http://s852.photobucket.com/home/gazhyde/allalbums)
If the sensor is stuck, you can use a flat blade screwdriver to ease them out. I replaced my rears on Thursday and they were a bit grubby.
Also you can use WD40 or similar to ease them out.
I didn't fancy trial and error for an hour or 2 on the driveway so went to my local indie. They diagnosed my faulty sensor with a code reader so it can be done with the right software Gaz.GazHyde wrote:I don't think you can check them without removing them.
Current...1998 ///M Coupe
Previously...1997 Z3 2.8
- leahandsteve
