dial colour change
walter05
dial colour change
Post by walter05 »
Has anyone tried fitting the tri coloured relacement dials advertised on Ebay/ Just wondering if they are an improvement on the black originals.
Re: dial colour change
Post by Southernboy »
I've replaced mine with white.....
Post by BladeRunner919 »
I have a suspicion that the op is contemplating these:
http://www.ebay.co.uk/itm/BMW-E36-Z3-PL ... 0707308624
littlefeller
Post by littlefeller »
how do you remove the needles to replace the dials? :idea: a couple of years ago I replaced mine on another car which I printed onto a overhead projector film, I also did this on a aprilia bike I had. it would only work on the bulb lit type dislays like on the z3. if you print your own you can have whatever design you like, even personalise it.
heres one I used as a template before I modded it, to give you the idea
you can open them in windows paint, like this, then edit
Captain
Post by Captain »
Use two teaspoons, place them under the needles and gently lever them off. Make sure you put them back in the same position :grin:
Sent from my GT-I8190 using Tapatalk 2
barbancourt
  Not specified
Post by barbancourt »
Ain't my style, Kyle.
barbancourt
  Not specified
Southernboy wrote:I've replaced mine with white.....
Your interior is pimp.
Love the red roll hoops. Is that factory?
Nope....the roll hoops idea came from a pic of another member's Z...he had them leather covered too... :D
barbancourt
  Not specified
Southernboy wrote:Nope....the roll hoops idea came from a pic of another member's Z...he had them leather covered too... :D
Nice. I was looking at a Z3 with a saddle interior and it had black roll hoops but a matching saddle color OEM looking roll bar wind deflector. Did they make the OEM wind deflectors in other colors than black?
Never seen any other than black. I guess one could have one made though :wink:
Post by gookah »
Captain wrote:Use two teaspoons, place them under the needles and gently lever them off. Make sure you put them back in the same position :grin:
you mean in the kitchen drawer so the missus doesn't find out..... :D
Captain
Post by Captain »
Exactly
Rafolian
Post by Rafolian »
I replaced mine with white (and to kph). Got them from e-bay for 5 quid and took approx 40 minutes from start to finish for complete job. Very effective, also done them on my bike.
Rafolian
Post by Rafolian »
Forgot to put the name, dials4U.com
littlefeller
hey that's cheaper than buying projector film and ink for my printer :)
wildeboy
Post by wildeboy »
I tried some silver lockwood dials, I liked them in the daylight although I had mixed comment from other people.
At night they were awful, very hard to read! I swapped them back after trying them for a month just to be sure. I might have some photos somewhere on one of the other computers.
OEM Roll Hoops
M50B25 Inlet manifold
BMC CDA Induction kit
Beige roof
walter05
Post by walter05 »
Hi,i managed to remove instrument cluster with a view to changing dial faces. managed to split cluster but how does one get at the gauges,cant see any screws or clips. any info appreciated
...there are 3 "twist=lock" devices which need to be turned about a 1/2 turn...then the perspex front face comes away. Once you have done that, you can remove the needles, and the face is glued to the front, but lifts off fairly easily.
walter05
Post by walter05 »
Many thanks Southern Boy! Spot on instructions. The white dials look great and finished needles with wifes red nail vanish.Now for the refit. Cheers!
lets see some pics of the resuts.... :wink:
