asc mode
asc mode
its a simple question but if I press the asc button the light comes on, now the question is with light on is the asc on or have I just switched it off? some cars default to on and you have to manually switch them off.
Re: asc mode
If you press the button and the light comes on then it's off.
Visit my Progress Thread - http://zroadster.net/forum/viewtopic.php?f=32&t=35276
Re: asc mode
Agreed - the system defaults to ON on start-up - also if the light flashes during driving then the system is controlling.gedo wrote:If you press the button and the light comes on then it's off.
You can check the system with your BMTechnics OBD.
Re: asc mode
The dash light is a yellow warning light - if it is illuminated, then the system is either turned off or has a fault and is disabled. As mentioned, the light flashes to show it is active. If you turn it off it will stay off until the next time you start the car, then it will default to on again.
Re: asc mode
guess that settles it. I did check it with impa, but I wanted to know how to switch it off, wasn't sure if it defaulted to on.
Re: asc mode
that's the ideaCaptain wrote:Makes the drive more interesting with it off
Sent from my GT-I8190 using Tapatalk 2
