I've read the threads and recommendations for replacement of seat bushes due to movement on braking and acceleration as I have a bit of movement on the drivers side.
Its very slight and I'm just wondering, as zeddies only done 39k if the bushes are heading for a catastrophic breakdown or I should just live with them?
How long should seat bushes last?
Re: How long should seat bushes last?
The movement will only get worse over time and annoying. Just get a kit from Aceman there a good write up on how to change them very easy job to do.
Mine lasted for 15 years!
Ours has no movement after 65k miles, unless they had already been changed!
When I closely examined mine (when changing for the new ones) it seemed to be a design fault rather than something linked to mileage. The grease on the "screw runners" appeared to have reacted with the original, soft rubber bushes and turned them into a black slimy mess a bit like a bitumen mastic. It was more apparent on the passenger seat where the bush hadn't been put under compression anyway near as much but had still turned into a soft mess.
I've heard of mineral grease doing this to the rubber "slider bolt sleeves" on the brake callipers and so a special silicone grease is recommended. Perhaps the same problem with the seat bushes - perhaps BMW used different grease on some later models?
My drivers ones were knackered at 61k, passenger ones still ok!
I bought my car with 73000 and the passenger seat needed doing, but the driver seat lasted till 84000 miles?
You would think that the drivers seat would need doing first?
