What do you guys use to jack up your cars?
I'm forever using my trolley jack and axle stands, but seriously considering investing in a car lift - or at least something a like a beam jack. It takes ages to get the car on all fours safely. Maybe I'm just getting lazy... ??
Notice this one in Classic Car magazine: http://www.cjautosheywood.co.uk/3in1.shtml
Whatever I bought, I would use it for both the zed and the MG, and it would be a long term addition to my garage kit that I'd plan to use a fair bit (I tend to crawl about under the cars either other weekend - always something to fix/check on one of them).
Cheers,
Tom
Mobile car lifts?
- Sponsor 2018
Re: Mobile car lifts?
Hi have a look at MR1car lifts Mike Dawes. I have looked at the mobile lifts but they appear to restrict the middle of the car. I think you may be able to buy the one your looking at cheaper if you shop around. Good luck. T.
TomH84 wrote:What do you guys use to jack up your cars?
Cheers,
Tom
I have one. and they are brilliant....:
And as regards access to the middle of car, there is a good 10" clearance above the frame so you can get exhaust, propshaft off etc etc:
It can be tilted either forwards or backwards so either end is up in the air, or locked in the horizontal position
I can tilt it on my own, because I know where the balance point is now to position it under the Zed.
Here is it next to my son showing how easy it is to access the underside.
It came with two taller 6 tonne axles stands, that you fit wherever you want to work. Plus I now use an electric drill to raise and lower it so it takes seconds to raise it fully.
Cheers guys! That's fantastic
Photos really helpful - thanks for those. Good to see that there's lots of clearance underneath. It looks pretty stable in the flesh too. Bye bye trolley jack...
Cheers again,
Tom
Cheers again,
Tom
TomH84 wrote:Cheers guys! That's fantastic
Cheers again,
Tom
I would not be without it now... and yes, it is stable, it's a heavy beast, and is a hell of a lot sturdier than it looks.
Don't throw your trolley jack, I have to jack up a couple of inches under the diff to fit it under, cos my car is lowered
