How is the air bag light still on?
gas guzzler
Post by gas guzzler »
Before anybody says anything I know its not ideal but I need the car to get through the MOT, it's not being sold on. Okay I've had a BMW mechanic check the fault and it's saying fault with side air bag somewhere, an expensive repair. Any way went to the MOT station and asked if it would fail with the light on, YES but if the light doesn't come on it's an advisory. So took the instrument pod out, removed the bulb put it all back, guess what the light still glows, just a bit fainter. HOW?
Andy
1999 Z3 2.8 RED, back with me
Re: How is the air bag light still on?
Post by bertiejaffa »
gas guzzler wrote:Before anybody says anything I know its not ideal but I need the car to get through the MOT, it's not being sold on. Okay I've had a BMW mechanic check the fault and it's saying fault with side air bag somewhere, an expensive repair. Any way went to the MOT station and asked if it would fail with the light on, YES but if the light doesn't come on it's an advisory. So took the instrument pod out, removed the bulb put it all back, guess what the light still glows, just a bit fainter. HOW?
There is a backup LED installed to stop you doing exactly this. Im not saying to do it but others have found paper stuffed in the hole to hide the LED.
gas guzzler
Cheers, thought I was seeing things, bloody German engineering. Shame they couldn't have made the rest of the circuit more reliable.
Andy
I had an airbag light problem that wouldn't go away, in the end swapped the airbag ECU for an identical part number 2nd hand one, works perfectly.
beerbelly
Post by beerbelly »
would have thought the only option was to fix the problem not how to get around it :?
Post by g8jka »
spurs fan in a coupe wrote:I had an airbag light problem that wouldn't go away, in the end swapped the airbag ECU for an identical part number 2nd hand one, works perfectly.
I also had the airbag light on permanently when I purchased my zed, but no code readers would read the ecu. Swapped this for an identical part and not had a problem since.
gas guzzler
I will fix the problem but at the moment I need to get the car MOT'd and checked over for any other problems to make sure it's a viable proposition. It can be one of three things, as it's not the contacts, have already gone through those several times. The ecu unit behind the console (not sure how much they are), the side air bag sensor attached to the cross member under the seat £107(no correct ones on ebay) or the air bag unit in the door £534 from BMW (again no correct ones on ebay). The Bmw guy said the side air bags are an integrated unit and that's why it's expensive, must admit though I've got the door panel off at the moment and it doesn't look integrated to me. Have already tried the by pass thing that didn't work.
Andy
beerbelly
Post by beerbelly »
has it been in an accident and any of the seatbelt pre tensioners been deployed not always obvious
Post by pingu »
There's nothing wrong with using salvage parts (as long as they haven't been out in the rain). That will cut the price down.
gas guzzler
Don't have a problem with salvage parts, normally try and use them, but no correct units on ebay at the moment. Already ordered a sensor unit that was supposedly the correct one for a Z3, listed to fit my car, but it was the wrong one, fortunately didn't pay much.
Andy
Do you have anymore for him?
Yep I've got a few, I'll check when I get home.
Got these 2 off cars, also have 1 from a 2.8 1997 and one from a 1.9 2002 reg.
swappy
Post by swappy »
Any tips on changing over the control module ? Just got one off ebay, same part number. Had a couple of fault codes using a B600 reader/reset tool it gave me a couple of fault codes but wouldn't reset them. One of the codes was F0 which according to the booklet that came with the reader was an error that meant the control module had an internal error hope swopping it sorts it out. Although my local mot station said if the dashboard light isn't working its an advisory, but i really would like it to work properly just for peace of mind and safety.
swappy wrote:Any tips on changing over the control module ? Just got one off ebay, same part number. Had a couple of fault codes using a B600 reader/reset tool it gave me a couple of fault codes but wouldn't reset them. One of the codes was F0 which according to the booklet that came with the reader was an error that meant the control module had an internal error hope swopping it sorts it out. Although my local mot station said if the dashboard light isn't working its an advisory, but i really would like it to work properly just for peace of mind and safety.
Mine was just plug and play.
I think a faulty air bag light (one that doesn't come on wen ignition is switched on and then go out shortly afterwards) will fail the MOT
Post by pingu »
spurs fan in a coupe wrote:I think a faulty air bag light (one that doesn't come on wen ignition is switched on and then go out shortly afterwards) will fail the MOT
No light at all = Advisory
Light on permanently = Fail
gas guzzler
Well finally got it MOT'd today after the speedo packed up last time I went to take it in. So it passed with an advisory on air bag light 'not illuminating' , the wonders of a bit of paper stuffed down a hole. Hopefully be able to get it sorted by next year.
Andy
Andy
Post by peter2b »
My air bag was on, the seat sensor had a thingy pluged into it but i replaced it with another one off ebay , light still would not go out, fortunely Robert T poped down with his lap top and sorted it out in seconds, but my R800 reader would not clear the light
stevov
Post by stevov »
Readers often do not have the ability to clear airbag and other safety codes. If they were so capable it would negate the reason for myself and other mechs from spending thousands on diagnostic equipment.
