All comments and suggestions welcomed!!
After my earlier post on the fuel gauge issue, I am now looking for the "rattle in the back"...
I have checked all the obvious items like shocks, exhaust, tank strap rubber cushions and bumper weights and all to no avail.
So... anyone who has come across more unusual causes, please pass on the info so I can check those too.
The rattle is only audible when the speed is low and the car isn't revving to loudly. It is apparent when driving over small frequent bumps - something like one would feel driving on cobble paving perhaps.
Once the speed is up around 30 - 40mph, I can't hear a thing.
I hope someone will have discovered the source and will share their knowledge.
Re: All comments and suggestions welcomed!!
Check the spare wheel, the cradle and all the parts, and that's its all installed nice and firm!
Cheers Paul...did that - spare wheel isn't fitted at the moment and everything associated is really secured well.
Somewhere I read that there is a "ball valve" fitted on the top side of the tank... Same system as a toilet ball valve. Apparently it's there to prevent fuel spillage in the event you roll the car.. Can't see the sense though... why have a valve at all ?? there are other vents for the tank already. I just thought that if that was true, maybe my ball is rattling in the valve..
I have a similar rattle that has been put down to worn CV's on the half shafts. The half shafts have about 10 mm longitudinal movement when you reach under the car and slide them to and back. If I set the shaft to the diff end, the rattle goes away until it works its way back. The outer CV has the slip joint and the inner CV should be tight but wear of the CV (110,000 miles) gives it some travel. Have checked it against a couple of other Z3's which don't have any shaft movement or the rattle.
Thanks buddy - I'll check those CV joints - could be the culprits..
To close this thread - I found the rattle !!!
On friday I stripped off the old roof and yesterday I fitted a new one. In the process of stripping, I was quite surprised to find the 19 large self tapping bolts at the back window area which hold the sealing and tack strips were quite loose. Anyhow, after installing the new roof, which requires adding strips of butyl for sealing, I parked the car in the sun so the butyl would soften before I did the final torque on those screws - I want to get max compression of the butyl for the best possible seal. Well the upshot of it all is that the rattle has gone. So I assume it was the plastic sealing strip or the tack strip which was the culprit due to the somewhat loose screws...
Thanks for the replies guys.
Always look for loose batteries rolling around
I did that in 1966 with my MGB and the culprit was a LR14 1.5 volt battery!!
Glad you sorted the problem
A friend of mine had a strange bump noise when accelerating and also under braking.
On further investigation it was a water bottle under the passenger seat
Z3 S54 M roadster
, BMW Z1, BMW M3 CSL, Z4M Coupe
Z3 S54 M roadster
