After my car's been out in heavy rain (standing) when I open the passenger door a no insignificant amount of water dribbles out of the rubber moulding at the front of the door. Sometimes the passenger carpet is wet, but not often. The water comes out at about the level of the bottom of the window? Is this the notorious "A" pillar leak?
Richard
Leak - Is this the A pillar?
Re: Leak - Is this the A pillar?
To check open the roof and squeeze the triangular plug/bung - if water oozes from around bung edges then it needs re-sealing. Simple enough job - dry it out with a blower and inject silicone.
