HELP NEEDED - UNDER CAR TRIM REMOVAL
Post by Southernboy »
I need to remove the trim on either side of the car...it's the part which runs the length of the car under the doors, front and rear fender panele...the part which also has the plastic clip on parts where the jack engages...any help appreciated
Fender2004
Re: HELP NEEDED - UNDER CAR TRIM REMOVAL
Post by Fender2004 »
Never done this yet but from other posts you have to remove the front and rear inner wings and also the front wing (fender).
Once these are removed it will give you access to the bolts to remove the side skirt.
Hope this helps :D
Post by Gazza »
Liam (Z3Cade) did a sill removal thread.
The link is in here http://www.zroadster.net/forum/viewtopi ... hilit=sill
Thanks gents...perfect! :wink:
Jonco
Post by Jonco »
Gazza wrote:Liam (Z3Cade) did a sill removal thread.
I used this guide last year to do mine - it's very good. I would add that you should also have a close look at the wing panel bottom lead corner when you have it off. The sealant hardens on this and comes away from panel creating a moisture trap. Also mask tape the door front lower corner as it is easily scratched by the bracket on the sill.
Colin
Thanks Colin....I'll do a full inspection and repair / restore anything needed.... :wink:
DarbyGloss
  Z3 roadster 2.5i
Post by DarbyGloss »
How much is a full car inspection costs?
I was referring to a full inspection of the sills of the car... :wink:
