Gearbox oil for a Roadster?
For owners of the Alpina RLE and Alpina Roadster
Leon.
  Z4 Alpina Roadster S
Post by Leon. »
Anyone know if it would be the same as a 3.0l, and what that takes? Grade and capacity?
Post by Jonttt »
Leon
Search (use the words "Gearbox AND oil" to narrow the search) will bring up quite a few posts about this such as
http://www.zroadster.net/forum/viewtopi ... earbox+oil
The gearboxes are marked as "filled for life" but the conscensous seems to be that changing improves the gearchange.
You could also ask Opie Oils for advice, they are members on here and post offers regularly and seem happy to advise :wink:
Post by Gazza »
Or you could :rtm:
:wink:
Leon.
Post by Leon. »
garythefish wrote:Or you could :rtm:
:wink:
You mean read the manual?
It's not in there :wink:
Leon.
Post by Leon. »
Jonttt wrote:Leon
Hi Jon,
I really wanted to know if anyone had any knowledge of the Alpina Roadster box and diff, but I appreciate your post.
I've felt the benefits of fresh box oil before and heard of the benefits on the Z so want to do it...
I've used Opie Oils before, and always buy the best stuff of them, trouble is, they don't always get the spec's right for the individual cars.
estocks
  Not specified
Post by estocks »
Alpinas use the same oil as the donor BMW. Since your's is probably the 5HP19 the oil would be the same as for that.
Leon.
Post by Leon. »
estocks wrote:Alpinas use the same oil as the donor BMW. Since your's is probably the 5HP19 the oil would be the same as for that.
Actually, it's a 6 speed manual, not 5 speed auto...
estocks
  Not specified
Post by estocks »
Have you tried searching the forum at the Alpina Register?
Leon.
Post by Leon. »
estocks wrote:Have you tried searching the forum at the Alpina Register?
Indeed I have. It was suggested to be the same as the 3.0l, but no definitive answer.
Perhaps I should call Sytner...
pdwarren
Post by pdwarren »
BMW use various "lifetime" oils, designated as MTF-LT-1, MTF-LT-2, etc.
As far as I can tell, you can't buy these directly in the UK but may be able to persuade to dealer to sell you a couple of litres.
Paul
estocks
  Not specified
Post by estocks »
I would strongly suspect your gearbox uses regular oil, since it is a standard gearbox. :wink:
Leon.
Post by Leon. »
edit.
