How to Repair the S50B32 VANOS
Post by pingu » Fri 16 Sep, 2016 05:22
Hopefully these videos will help you decide if you want to take on the dreaded rattle or poor performance.
It will cost you around £150 to get it sorted if you DIY. Now that I know what I'm doing, I could do the full repair in a long day.
You should still read the Beisan instructions (Seal Replacement and Rattle Procedure) before you attempt the repair, but I'd also advise you to view my videos as well. Also read the BMW TIS if you have access to it.
There are linked videos within the videos and I'm not sure how the YouTube viewer will handle them, so I've included the links so you can go directly to the source if it all goes wrong :) ....
Removing the Vanos
https://youtu.be/aiLbv35Mhws
Removing the VANOS and the Diaphragm Springs
https://youtu.be/jgRI5t12GxY
Overhauling the VANOS
https://youtu.be/uE89Tzd3Ajk
Servicing the Pinions
https://youtu.be/LwVoT0hC9AQ
Servicing the Solenoids
https://youtu.be/XOiL03p6zNc
Stretching a TEFLON Seal
https://youtu.be/ybacuikGxzY
Cleaning the VANOS Pump
https://youtu.be/2aHofBcfZvI
Refitting the VANOS
https://youtu.be/QnSKuOjqAok
Advancing the Timing Chain on the Exhaust Sprocket
https://youtu.be/Mr2Jqnbkmw0
Measuring the Valve Clearances
https://youtu.be/7JFEcR9x7nk
Re: How to Repair the S50B32 VANOS
Post by bertiejaffa » Wed 21 Sep, 2016 10:11
Well done fella - you could now make a lot of money if you wanted !!
Post by pingu » Wed 21 Sep, 2016 13:22
bertiejaffa wrote:Well done fella - you could now make a lot of money if you wanted !!
Been there, done that :)
I'd rather have time to spend a little than lots of dosh and no time :wink: .
Joycey
  M roadster S52
Post by Joycey » Thu 29 Sep, 2016 10:48
Cracking video Pingu!
Post by pingu » Fri 14 Oct, 2016 17:52
I've just priced the whole job.
Seal Kit - Beisan - $80 (£65). Best price on eBay is £55 (includes the solenoid seals which Beisan doesn't include)
Anti-Rattle Kit - Beisan - $80 (£65)
Anti-Rattle Tool - Beisan - $20 (£16) You could try to hold the pinion in a vice, but you would probably fail without the tool and damage the pinion.
Camshaft and Crankshaft Timing Tools - eBay - £46 (not essential, but makes the job a lot easier)
Solenoid Plug Diodes - eBay - £10.33 for various diodes, most of which were wrong. The correct ones cost £2.95 for 10, but I only needed 2.
Diaphragm Springs - BMW - £48.21 (£43.39 with 10% discount)
Solenoid O-Rings - BMW - £49.97 (included in eBay kit)
Timing Chain Tensioner Seal - BMW - £0.30
Solenoid Cover Gaskets - BMW - £16.06 (not required unless badly damaged)
Thrust Washer - BMW - £7.72 (£6.95 with 10% discount)
3x Valve Shims - eBay - £10.03
Some switches and terminals to make a solenoid activation tool - eBay - £3.80
I also had to buy a 24mm open-ended spanner - Halfords - £9.99
So, the total cost was just a little bit under £350, but with more knowledge (and if I had the tools, or make do without them) I could have done it for around £210.
elwood158
Post by elwood158 » Thu 09 Feb, 2017 01:19
Pingu, great post mate.
Love your work. Unfortunately, I'm not techie enough to attempt such work but will direct my mechanic to this post when I decide to do some fixing up....
Elwood
1999 M Roadster (S50)
Porsche 911 RS hotrod
Post by c_w » Thu 09 Feb, 2017 21:09
Nice. A lot of work gone in to making those videos!
Martini
Post by Martini » Thu 11 May, 2017 11:32
A great job, thanks for sharing all that!
Cooper01
Post by Cooper01 » Fri 12 May, 2017 13:19
Great job! I am replacing the rocker cover gasket and thought I would replace the Vanos seals while I have it all apart anyway. Just waiting on the parts now. No other work will be done.
