Lower control arm Z3 M
Discussion of anything to do with the BMW Car Club. Viewing and posting limited to Z Register members.
Zippy181054
  M roadster S52
Post by Zippy181054 » Mon 22 Oct, 2018 16:15
Anybody know where I can source a pair of lower control arms for my M Roadster 1998, or are the standard Z3 control arms the same? Thanks
Sent from my SM-G955F using Tapatalk
Re: Lower control arm Z3 M
Post by Gazza » Mon 22 Oct, 2018 17:43
Www.reaioem.com lists the lower arm as different for the Z3M to all other Z’s
31122228461
31122228462
Euro carparts list them, two brands, £84.99 and £128.99 each
Zippy181054
  M roadster S52
Post by Zippy181054 » Mon 22 Oct, 2018 19:05
Thank you Gazza will try them tomorrow
Zippy181054
  M roadster S52
Post by Zippy181054 » Fri 26 Oct, 2018 12:49
Bought these from Euro car parts with an additional 35% discount, £110 the pair, getting them fitted Tuesday as I can't seem to get to the middle ball joint nut from ground level and don't have a ramp.
Post by Gazza » Fri 26 Oct, 2018 16:12
I’ve heard that joint is a pain.
Great result on the price
Post by Del » Sat 27 Oct, 2018 21:00
On my 1.9, I accessed them from above using a couple of connected half-inch socket extensions and a flexi-joint - this gave just enough wriggle room. On your M I am guessing the engine bay is a little more cramped? :) From below I then simply drove a splitter fork between the ball joint and chassis crossmember. Once the drop-links are disconnected with the car level, the control arms can be tackled individually by jacking up each side in turn.
Zippy181054
  M roadster S52
Post by Zippy181054 » Sun 28 Oct, 2018 00:18
Thanks Del, I think the set up is slightly different on the M where it needs to be raised, not only that I got a spanking price on fitting the pair, hardly worth dirtying my hands
